Results 1 to 2 of 2
    Dec 2003
    Sutho Shire y0. REZPECT
    1998 BB6 Prelude VTiR
    Well Well Well
    Today was educational.
    I took these and used them wisely... :jus:
    Originally, my wheels were here, inside the arches
    But first, I gave them a quick sand back - nothing harsh
    A lick of paint...
    And removed the original items
    from here - these 2 bolts are on the LCA
    and take them off at the cross member from here
    Rather simple - Must use tension wrench, bolts tightened to 130lbs.
    Then we stuck them on, and did a wheel alignment - which didn;t work due to wheels being more outward than the tyres, so the measurements were wrong - however, I thik it worked anyway, no reason to be believe the wheels were toeing in or out. I believe the measurement equates to 3 flats movement inside on the tie rod ends
    I shall have more pics when the sun comes up
    End result -
    35mm longer wheel base
    8Degrees of castor (Honda standard is 2 degrees)
    Slightly stiffer steering - a good thing
    Tyre rub on inner guard at standard height at 1.5 turns or more of the steering wheel
    Turns in LIKE A BITCH - unbelievable, however need new rear tyres.
    What happened on first test run
    I get dorifto action when I back off the gas on corners - rear tyres a rooted, plus the rear stabiliser is quite stiff, so that accentuates the issue with baldies and lots of turn in.
    In Conclusion
    YOU JUST HAVE TO DO IT!!!!!!!
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    awesome DIY.
    are you able to fix up some of the pics?
    SSpamily
