Page 2 of 32 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 380
  1. #13
    May 2006
    Brisbane
    380GT,XTrailSTR
    also i'm not sure people realise with the turbos in those cheap kits.
    They work well for the bolt-on setup... they generally have a 4psi actuator spring which is pretty much the max they should be running as a "bolt-on". what people have to realise is that theres a reason the bolt-on kits don't come with bigger injectors, ecu or boost controllers... you can't boost them. if you really want those cheap kits with everything sourced for you already then fine... but at least visit any Nissan forum and get yourself a 2nd hand turbo off a Skyline or sylvia or something.. depending on the flange...
    Quote Originally Posted by Slow96GSR
    If 1 person has had bad luck with a product don’t condemn it until you yourself have tested it. Now if 10 pros have tried it and it sucked then I would trust their opinion.
  2. #14
    Feb 2007
    Honda Euro 2004
    yeah i get ya, so if i get a turbo from america are u saying i should bring in all the piping etc of there too, wouldnt it be different for them?
    can i use stock ecu for stock boost? 5psi
    civic 97 ek1 (1.6T)
    Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.
  3. #15
    Green block gangster Array
    May 2004
    twin GX160's
    no you cant use a stock ecu for any boost,
    your ecu has to modded and remapped
  4. #16
    Mar 2006
    Perth
    CZ4A,EG-K,PP-K
    Quote Originally Posted by ECU-MAN View Post
    yes that true ..
    But some company give their programed piggy back to run their turbo..
    Greddy usualy have FIC included in their kit
    fuel adjustment and msd boost timing controller...
    i found out they are not the best way to run turbo.. (NOT SAFE)
    too risky to run it ...
    so if you want to get a kit of usa ...
    u got the hardware parts..
    i recomend Treadstone .. they give you basic parts only no ECU or any fuel controller. they are arround $2700 mark
    this includes turbo, ext waste gate, intercooler, down pipe, etc
    www.treadstoneperformance.com
    they willing to ship to australia which is kinda good hahahha
    then you provide your own Piggy back system or stand alone ECU, + bigger injectors. you wouldnt need fuel pump if your fuel pump still capable of running it less 80% duty.
    Run a piggy back to save u money ...
    Interceptor, emanage blue, emanage ultimate, hondata, fcon etc
    or you can run Stand alone which give total control of ur car!
    Power Fc, AEM, haltech series or microtech series.. try stay away from WOLF3D ... if its possible
    there you go.. a easy set up which cost you arround $4000 - $5000 inlcuding tuning and installing
    Good luck
  5. #17
    Feb 2007
    Honda Euro 2004
    hmmm i was thinking i might get a second hand turbo with all part excluding ecu... for around $1100-1200...
    second hand aftermarket ecu on ebay...
    and then pay for labour...
    this should run it at 5psi (ish)... i dont belive a turbo setup should cost 5k unless u want a nicely setup... i just want a "itll not wreck the engine" setup...
    civic 97 ek1 (1.6T)
  6. #18
    Feb 2007
    Adelaide
    CRX
    ye ive been discussing with rnbguy on PM and ive heard that you dont need diff ECU because its bolt on kit and were not changing injectors, I heard the manifols sheer but i can get one made up from my mate he makes them all the time for silvias and skylines just want a base kit to build off of
  7. #19
    Mar 2006
    Perth
    CZ4A,EG-K,PP-K
    prepare ur self a 5K budget ... just incase you will surprise!
    ECU will be arround $500 - 1500 depends on what are you getting.. and tunning will be another $400 - 1000 (on dyno)
    dont forget labour is the most expensive area
    what happen if your parts need to be moded lil bit to fit ur car? and exhaust work?
    5 psi ish .. will do something if you arent carefull enough .. just take some extra percautions on they way. it will save you money at the latter stage (if something breaks down)
    hope it helps ya to decide
  8. #20
  9. #21
    Mar 2006
    Perth
    CZ4A,EG-K,PP-K
    Quote Originally Posted by serpo View Post
    yep u dont need a diff ecu
    coz they give you their mini piggy back system.. for fuel control
    MSD BTM for timming ..
    frankly msd btm only can retard the timing by 0.5 over 1 psi of boost.. thats why u only can run a certain amount of boost on this set up.. no more than 6 psi may be 7
    i did some research on MSD BTM on the net .. comes out that it will advance timming at high boost ... might try to do some search in depth b4 you going a head with this parts
    and injectors arent necessary... as long as their duty cycle are no more then 70% if they were.. u have to change it
  10. #22
    Feb 2007
    Adelaide
    CRX
    the ebay item doesnt say anything bout piggyback
  11. #23
    Feb 2007
    Honda Euro 2004
    come on guys, surely someone here has done a turbo setup without going the typical $5k budget, speak up pwez
    civic 97 ek1 (1.6T)
  12. #24
    Mar 2006
    Perth
    CZ4A,EG-K,PP-K
    =\ what kind of part u looking for?
    i think piggyback is just to have a total control of ur setup..
    u can run with out it. by using a fuel pressure regulator probs
    http://cgi.ebay.com/ebaymotors/INTEG...spagenameZWDVW
    this runs with SAFC
    http://cgi.ebay.com/ebaymotors/Turbo...spagenameZWD1V
    if you see the picture, they have msd BTM and next to it there is a black box which is FIC *fuel control module
    if you talking about the link on the 1st page ... i wont run on ur car properly .. you will have detonations and lean fuel as the turbo spools up. on full boost.
