since they are a softer compound - under stress and heat i would think any repair would fail.
Besides , you are using semi slicks to the limits...why fix it for $30 and get a blow out ?
I actually had a repair for my A0-38 soft compound b4, it works great on it after the repair, i had not had any problem. but you need to consider how long the rubber would last because if it has only 20-30% rubber left, i recommend you to get the new one.
thats my personal opinion.
My thoughts are with this guy ^^^
To add, my thoughts:
If your using just for street, repair would be fine as it is for normal street tyres.
If your using for track then I might think twice about just getting a new tyre.
is it fine to run one tire with 100%, and 3 with 60-70%?
In short, No.
Compound properties and breakdown changes significantly. Once R compounds are heated up and cooled down, which you would have if you have 60-70% life remaining.
What you'll end up with is inconsistent grip and temperature control on 1 vs. 3. The older tyres will take longer to warm up and offer lesser grip than the newer tyre which is the last thing you want if you are using the R compounds on a circuit.
I can tell you that the steering wheel wont be straight if you run on one new tyre and the 3 old tyres coz I have done it b4, it doenst really matter if you have the new one in the front or at the rear, the steering wheel will twist on one side for sure. how about u trade in the other old tyre and have two new and two old? i think it will be the best idea if you can afford two new tyres.
