Originally Posted by JohnnyVtec
You shouldn't generalise all B16's in the same category as yours. There is (Monumental) proof in research that many stock & modded variations of the B16b,B16a-1-2-3 honda engines are far from gutless.
If you say yours is a dog, i believe you
i dunnoes, stock ones, are gutless, they don't breathe.
lol.
been in a ek4, eg with a b16a2, and my del sol, all about the same.
lol
Originally Posted by matt
k20's are from DC5, EP3, some FD's including new Type R, and the FN2. im pretty sure thats all of em.
k20a JDM DC5R 162kw
k20a JDM EP3R 158kw
k20A2 AUDM DC5R/UK EP3R/US RSX-S 147kw
K20A3 DC5 Base 118kw
K20Z AUDM DC5S 154kw (i can never remember what number this engine is 1,2,3 ???)
You forgot the Accord Euro-R's
Should be the K20Z1 for the AUDM DC5S.
Better to have it and not need it, than need it and not have it.
b16a are a very good motor. I know someone thats currently building a b16a that gonna rev to 10k. Don't under estimate them.
For track, suspension setup is very crucial. I don't see why ppl spend so much money on there motors but don't have the money to buy "DECENT" rubber.
Build up the suspension and go track the car. Practice and make changes to the suspension to suit. There is no point having a k20 powered honda and you dont know how to drive. Learn how to drive on the circuit first then get more power if needed. The b16a are a very good platform engine, and would go well in a car that has proper track set-up.
For example. A stock engine swift with full suspension mods can hit 1:14's around wakefield. They only have 60KW ATW
Swift >honda muhahaha
Haha i think you should take that back. Last time i remembered i pass you along the straight and were 2 seconds quicker than you
[QUOTE=Benson;1192088]Build up the suspension and go track the car. Practice and make changes to the suspension to suit. There is no point having a k20 powered honda and you dont know how to drive. Learn how to drive on the circuit first then get more power if needed. The b16a are a very good platform engine, and would go well in a car that has proper track set-up.
While i understand and agree that his driving skills & car should be up to scratch with the track, it doesn't make much sense to take his GLi out and fit/tweak/tune all the proper suspension+tyres to suit the track, then install a bigger or more powerful engine and completely different geared trans. it would be a waste of time as well as money if you ask me.
I'm no expert, however i hope you understand the validity of my point
So you mean after the engine swap he'd have to redo most, if not all, of the suspension tuning thats been done??
Well, it makes sense to me....
i see what you mean but i don't think it'd be as big a impact as you think.
How much weight difference is the motor?? How would it change the weight dist of the car etc They're the sorta things you'd have to look at.
Probably just need to get the corner weights redone and get used to the extra power i think. Most of it would probably be driver experience that would need to be improved.
I'm in the same boat as you though. Not much experience but a descent amount of reading.
I do know that a sussy setup can make or break a car tho so thats where i'd be looking at.
I do understand your point but you don't need to change the suspension that much to suit the heavier motor. Maybe just put heavier springs in the front. The behavior of the car wouldn't change that much. As for tyres, always get a set of decent semi slicks for the track even if you have a slow car.
I wasn't uncertain about the weight difference between d-b-k series as i am about the power outputs, gearing, braking, and steering. Example: you do 6 laps in a d16y4 ek hatch, then you get into an ek hatch with fully built B or mild K series and try to drive the car exactly the same.
Jason, i think you're correct to the extent that it would mostly depend on the drivers capablity and experience. however i do believe that there would be some differences in which even a well skilled driver couldnt completely absorb.
