Boston Acoustics , clarion, rockford fosgate, JL Audio, Kicker, kenwood are decent brands. Or jaycar if you are on a budget.
Avoid crap like sony and the low end pioneer stuff.
Get an Amp if you are gonna replace the speakers. If you install high wattage speakers, the treble will sound good, but there will be virtually no Bass at all, and the Mids will be lacking. The stock speakers are actually ok for the stock deck.
Get the headunit first, then the Amp, then the speakers. I wouldnt Amplify the stock speakers though unless you turn the Gain right down, you could blow them since they are very low wattage.
You need two channels for the front speakers+tweeters, two channels for the 6x9's, and one or two channels for the Subwoofer.
I would get a small 2ch Amp at the front to power the fronts, and something like the Audison SRx3 (3 channel amp) to power the 6x9's and Subby at the rear.
There are no speakers in the rear doors, its just an empty hole with a grill over it. You can put 6" speakers in there, but you may need to route the wires into the doors - not sure if there are stock wires in there from the factory.
The system is still brilliant, the sound quality is fabulous.
I am still using the same head unit and steering wheel controls that came with the Euro. To look at the car you can not tell anything has changed.
I had it all done by Northfield Moorooka - Absolutely Terrific Service
Full Installation, All wiring Etc, No Cutting http://www.northfieldmoorooka.com.au
Front Door Speakers and Tweeters - Focal 165 V Slim
The BEST and ONLY Speakers That Will Fit With Out Cutting .
Focal Polyglass speakers use one of the most unique woofer cone materials that we have ever come across. Focal uses a unique process to deposit a layer of hollow silica micro-balls over specialized pulp cellulose cones. This unique material, which feels a lot like sand paper, neutralizes the effect of standing waves along the surface. Polyglass stiffens the cone while significantly increasing neutrality and imaging qualities. The unique 1-3/4" TN 45 tweeter features Focals unique inverted titanium dome design which provides far better mechanical coupling to the voice coil than regular dome tweeter designs. This creates an upper end with resolution and detail that other tweeters simply cant touch. The tweeters come complete with accessories for flush or surface mounting. All Focal products are handcrafted in France, with every component manufactured in-house under the tightest quality control standards. Designed to fit oversized 7" 4-hole openings. http://www.focalaustralia.com.au/polyglass.htm
Back Speakers 6x9 - Eclipse SE8493
Key Features
Size: 6 ? 9" 4-Way
Continuous Power Handling: 75W
Music Power Handling: 150W
Frequency Response: 50Hz-40Hz
Sensitivity: 98dB
Cone Material: Mica/Poly
Surround Material: Rubber
Voice Coil Former: Kapton
Midrange Dome: Mylar
Tweeter Dome: Mylar
Super-Tweeter Dome: Mylar
Tweeter Magnet Material: Neodymium
Woofer Magnet Material: Ferrite
Mounting Depth: 3 1/16" http://www.eclipse-web.com/
Amplifier - Alpine MRP-F240
V-Power 4/3/2 Channel Power Amplifier
This 4 channel V-Power amplifier delivers exceptionally high performance and detailed control. Combined with Alpine's famous sound quality, it's versatility will allow it to adapt to many configurations.
# 75W x 4 (Max)
# 100W x 2 RMS [4Ohms - Bridged @ 14.4V (0.3% THD)]
# 50W x 4 RMS [2Ohms @ 14.4V (0.3% THD)]
# 40W x 4 RMS [4Ohms @ 14.4V (0.08% THD)]
# Bass engine
# HP/LP Crossover
# Bass EQ (Variable Ch-3/4)
# RCA or Speaker Level Inputs
# MOSFET Output Transistors http://www.alpine.com.au/
The sven4 line level converter is the only LLC that we have found that does not introduce engine noise to the system in a Euro. inc, alpine, cali gold, and a few others. (same with BMW systems.)
For the Ultimate in Sound Quality and Signal transfer the SVEN4 is the Only Solution.
The SVEN4 was recently awarded the coveted innovations award at the 2004 Consumer Electronics Association Show.
Four channel Premium Sound Interfacing Device.
RCA level or speaker level input or output. The SVEN4 is perfectly suited for replacing the factory amplified system and retaining the OEM radio or for Premium OEM head-unit replacement. It can also be used as a standard line output converter. (LOC applications require vehicle specific sound harness--sold seperately).
NOTE: 60 watts maximum input per channel.
