I found out that the temp is like 90c in a weather of 34c at the speed of 90-100kph, and if I drive like 100-120kph it will hit 100c and stay there and if I floor it and drive hard it will go up to 120c, so I think oil cooler is important, if you drive hard, and in hot weather.
If you go fast then you rev is up. I have CVT so when I floor it it's 6k all the time.
but faster you go more wind to cool down ...
if you going on Highway doing 110km/h on a flat road unless you wants to go quicker otherwise you not in a very high rev range and the wind is cooling it very quick... so you would not heat up much
Wrong because also my water temp raises if I go fast and high rev and also wind hitting the radiator.
do any of the people commenting in this thread even have half an idea or are they just guessing/making it up?
kimi - here are my thoughts:
1. you should be measuring the oil at it's hottest.
2. the reason we care about oil temperature is that it 'breaks down*' above around 130'C and risk of bearing failure is increased
3. heat relates to load, not speed.
4. if you ARE seeing 120'c oil temp with YOUR driving style - you NEED and oil cooler for relaibility.
Yes, Tink is right. The right/proper temp should be taken at its hottest, ie in the sump. I spose I am a bit swayed in thinking because I have a remote filter with the Temp/Pressure in that mount and it is after the cooler as I want to see my pressue going in to the motor.
