Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
    Not sure if I covered it in the PDF, but I ended up using a long bit of sticky tape to get a hold of it and move it into place, then once it was there, I pushed in a bit so it stayed there and tore the sticky tape off.
    I assume by now you've gotten it back in already. How did you end up doing it?
    Jan 2009
    '01 DC2R
    yeh i think its in lol got a friend with small hands to go under the steering wheel and wiggle it till its almost touching then i just pushed the headunit in
    So it turns out there was something wrong with the instructions causing the bad sound quality. I finally decided to properly mount the socket into my car and discovered that one of the pins described in the instructions was wrong. I have updated the guide to fix this.
    (The bad sound quality was caused by a grounding issue because the ground wire was not connected to the right pin in the connector - should be AUXSG in the diagram, not AUXSH.)
  4. #16
    Mar 2012
    FD 1 2006 VTIL
    bit of a nooby question here, is the system connector 2 part of the car? or was that connector purchased separately?
    also
    Is there an update of which gear to buy? seems like jaycar dont sell these products anymore
    thanks
    Simon
  5. #17
    Quote Originally Posted by simonhaha View Post
    It is part of the car.
    The easiest option is to find a CDROM audio cable as shown in the instructions. They're a bit harder to find nowadays because they aren't used anymore I don't think. I'd try eBay or computer parts stores like CPL or MSY.
    Here's an eBay listing that should work, but they're a bit expensive in my book - http://www.ebay.com.au/itm/24-Digita...-/290693121141
    Here's a Google search that might have a few more leads - http://www.google.com.au/search?q=cd...n&cr=countryAU
    Hope that helps.
  6. #18
    Hello Sam
    Thank you very much for the detailed instructions, worked perfectly.
    Greatly appreciated.
    In the course of my installation, or more to the point, in the course of re-fitting everything, i found an effective way to deal with the plastic air tube you mentioned.
    Disconnect this tube from under dash
    I have included a couple of pics here.
    I hope this helps anyone else attempting the same.
ID:	27249   Click image for larger version.
