Page 7 of 8 FirstFirst ... 45678 LastLast
Results 73 to 84 of 94
  1. #73
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    Quote Originally Posted by hectic_filo View Post
    which paint did u used mate? is it the VHT sp240?
    how did u dry this one?? out in the sun or u oven it? also the letters?? sanded it?? taped it or pva glued it??
    cheerz
    looking hot bro!!
    Very hot. Love it...
  2. #74
    DC2R, R6
    cheerz
    looking hot bro!!
    Yep got my VHT from autobarn. Gave the original paint a light scuff, dont bother stripping it back, then mask it up.
    I let it air dry in the shade, gave it 2 coats and let it dry for 2-3 days. sanded the letters with a block, the sanding is the most teadiest part of the job.
    Looks better than the original IMO.
    Jords.
  3. #75
    Apr 2009
    QLD
    ED Sedan
    Its not a DOHC but here mine is...
    Fortunately there was no original paint for me to remove..
    Its not really necessary to oven bake the cover after you've painted it. It'll get baked in your engine bay. On a previous cover I've done I left the logos for 2 weeks to harden before sanding them off.
  4. #76
    Nov 2008
    2766 NSW
    C34/RE7/ED6/FN2
    Quote Originally Posted by markismaximus View Post
    nice work dude looks hot.. mines is not a DOHC either but its a VTEC-E planning to paint mine red, so you painted it.. how long it took u to put the cover back after spray?
  5. #77
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    I'm planning to do both my B16A and D16Y1 when I get back from Europe...I love my SOHC D
  6. #78
    Apr 2009
    QLD
    ED Sedan
    nice work dude looks hot.. mines is not a DOHC either but its a VTEC-E planning to paint mine red, so you painted it.. how it took u to put the cover back after spray?
    maybe 30 minutes to put back on, taking your time obviously. I cleaned all sealing edges and the bolt seals, applied gasket silicon to prevent any future oil leaks. If you just put it straight back on it would take about 5 mins
  7. #79
    Jan 2009
    Templestowe
    90 EF8 siR
    This what is did, just sanded it back to a nice smooth surface and hit it with primer, i got a spare one which was stripped.
    I originally wanted to go for gold, i got a few coats on but then the can decided to crap itself and shoot paint all over the place and bacme blotchy
    so i sanded it back a bit and hit it with a sexy red
    Ripped off the old one, replaced all rocker cover bolts, nuts, gasket and seals to brand new and torqued them to spec
    Presto, applied a few coats of matte clear, sanded back the letters very carefully, turned out well, was baking on monday in the 43 degree heat.
    Then the day after i had to strip all the paint off the other one, i was aiming to paint it spoon yellow, i didn't have paint stripper laying around, just my luck
    Used a little blade to get the stubborn paint off, and different varietys of fine and rough grit sandpaper, It only took me about 4 hours
    Primed her up
    First coat was yellow, but i wasn't really happy with it, the paint quality was awesome but it think it would stand out way too much in the bay, so i decided to mix it up a little
    Brother and sister
    So now that my rocker cover is red, i now have an extra 25kw at the wheels
  8. #80
    Nov 2008
    2766 NSW
    C34/RE7/ED6/FN2
    i mean.. how long it took you to wait to dry the paint before you can put back the cover back to the engine?
  9. #81
    DC2R, R6
    wait at least 2- 3 days
  10. #82
    Ozhonda Trader Array
    Aug 2003
    Sydney.
    EGK24A
    My K series rocker cover in wrinkle black
    JDMyard Pty Ltd
    www.JDMyard.com
  11. #83
    Dec 2008
    Milano Red EM1, CU2 Euro
    they look good, i should motivate myself and paint mine
  12. #84
    Aug 2003
    Sydney.
    EGK24A
    Polished Nuts.
    New polished grommet gasket
    Painted spark plug wire cover.
    OEM Type R oil cap.
    JDMyard Pty Ltd
    www.JDMyard.com
