Page 1 of 2 12 LastLast
Results 1 to 12 of 24
    Newcomer Array
    Jul 2004
    NSW
    CRX SiR
    I am about to do the B16a conversion into my 89 CRX.
    Just noticed the speedo in the EF half cut only shows 180kph max.
    Does this mean the CPU will cut the engine at 180?
    If so, how do you defeat the speed cut?
    The [acronym:37802641e0="Engine Control Unit"]ECU[/acronym:37802641e0] , if you are using the [acronym:37802641e0="Japanese Domestic Market"]JDM[/acronym:37802641e0] ecu will be limited to 180 km/h .
    To defeat the [acronym:37802641e0="Engine Control Unit"]ECU[/acronym:37802641e0] limited speed- you will need a aftermarket piggy-back or full [acronym:37802641e0="Engine Control Unit"]ECU[/acronym:37802641e0] .
    Im sure the actual transmission is geared to alittle more than that....but basically - why do you even want to think of going faster ?
    Isnt it "[acronym:37802641e0="Japanese Domestic Market"]JDM[/acronym:37802641e0]" to have a 180km/h speedo ?
    Aug 2003
    PERTH WA
    dc2r
    or you can use the jdm ecu with a speed cut defender
    Aug 2003
    PERTH WA
    dc2r
    no need to shell out for piggyback
    ROKAGESAMA Array
    Sep 2003
    Sydney
    2009 Lexus ISF
    use pivot speed reader or sumthing like that
    that'll cut it out too
    my mate uses on his 180sx
    Team Bacchus Racing Lexus ISF
    Bacchus Energy drink
    Drive your Energy
    Newcomer Array
    Jul 2004
    NSW
    CRX SiR
    If you have ever been down Eastern creek straight you would probably not need to know why I ask that question.
    Sep 2003
    Melbourne
    Just buy any version of the Apexi RSM... it will unlock the limiter, no piggyback [acronym:f3f234cedd="Engine Control Unit"]ECU[/acronym:f3f234cedd] needed.
  8. #8
    May 2004
    Melbourne
    The FN2R
    not everyone can hit 180km/h down da quarter.....so y do u need to speed cut it?
  9. #9
    Dec 2003
    Sutho Shire y0. REZPECT
    1998 BB6 Prelude VTiR
    Quote Originally Posted by alan";p="109405
    how about the Circuit.. I know a lot of cars that crack 200km/h........
    Either way, a seed cut defender is the cheapest option normally
  10. #10
    May 2004
    Melbourne
    The FN2R
    i said quarter, as in drag (400m) quarter mile... :lol:
    besides, is it so bad to drive wif a spd limiter, don't hear ppl complain about the euro car's 250km/h limiter
    maybe actually cut it when u know u can go faster den it...
  11. #11
    Apr 2004
    wagga wagga
    CD5 vti-s
    i have a speed limiter now that i put [acronym:cb8f8bf91a="Japanese Domestic Market"]JDM[/acronym:cb8f8bf91a] h22a in my accord, it does annoy me.
    I understand that its possible to over ride this but actually how do i go about doing thins?
  12. #12
    yes it will have a speed limiter, and like i told you i can chip your [acronym:781684fe80="Engine Control Unit"]ECU[/acronym:781684fe80] to remove the limiter if your really think it is necessary...
    this goes for most ecus, but is easiest on the OBD0 ones...
    B20VTEC - since 2002
