Results 1 to 11 of 11
    May 2007
    Blue Mountains
    MY06Euro Lux Sat Nav Auto
    Front Tower Strut Brace
    Hi there,
    Would I obtain any obvious/noticeable benefit from fitting a front tower strut brace (like a Cusco) to a MY06 Euro that has not been lowered?
    Thanks for your opinions in advance,
    Cheers,
    Mike
    all it'll do is stiffen up the front, which in theory should help reduce flex
    i personally think not. because the suspension is stock and soft, most of the cornering - be it hard or soft, will be absorbed by the shocks and springs, hence, less chassis flex.
    if say, ur setup is very stiff, then more of the flexing would then be placed on the chassis, as ur sussy wouldnt be as accomodating. hard to explain but.
    spoke to a guy who tunes subarus.. he said during normal , day to day driving, doesnt make much of a difference, but if high speed tight cornering, then it will make a difference.
    then again, i'm an e-mechanic in this area, as i;ve never fitted one (bought, tried, didnt fit ). But i do have aftermarket sussy and i can tell the car creaks alot more due to the chassis taking more of the cornering loads
    Aug 2006
    Sydney
    06 Euro luxury manual
    Quote Originally Posted by SiReal View Post
    Hi Mike.As above^^^.i've got one(Cusco)but ive got Bilstein/Eibach setup,it does make a difference.If you're stock i wouldn't bother
    Jan 2004
    Melbourne
    ED Civic & 380GT
    it does help steering response on even stock euros. Very noticeable with quick changes in direction. But your first mod for suspension should be rear sway bar.
    Array
    Dec 2004
    Sydney
    Disco Potato
    Quote Originally Posted by yfin View Post
    2nd this. Rear sway bar like a SWIFT sway bar or a whiteline flatout will give you a much more noticeable reduction in body flex. couple that with a cusco front strut, lower arm bar and eventually if u do decide to lower ur car, turning corners should be a breeze
    Fast and furious? I drive slow and luxurious...
    Jun 2007
    ACT
    Accord Euro Luxury
    Quote Originally Posted by Mike Star View Post
    Hi there,
    Cheers,
    Mike
    to be honest i didnt notice anything... maybe because of two things, stock suspension is soft, and two, the euro already has a front strut brace (that weird bendy black thing). i went for the aftermarket strut brace because of the bling factor :P
  8. #8
    May 2007
    Blue Mountains
    Thanks for all your opinions
    Thanks for your opinions guys I appreciate them. I must admit that I was also looking at the Bling Factor too but maybe the rear sway bar might be the better practical starting point and then do the front brace after that. Where are the best places to price and source the rear sway bars?
    Cheers
  9. #9
    Oct 2004
    Sydney
    CL9 Euro, Evo 8
    It does make a noticeable difference in steering and response (with or without suspension upgrades), but not as much as the lower tie bar imo.
  10. #10
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    On my car, didn't make much of a difference under normal driving. There is only a difference when you are cornering real hard. The lower arm bar had a bigger improvement. I could feel it the moment I put it on. The steering felt less dead in the middle, improving steering response. IMO, go for a rear sway bar and coils first. Those make the biggest difference.
    Stocky CL9 - 1:17.2
  11. #11
    Jun 2007
    ACT
    Accord Euro Luxury
    Quote Originally Posted by aaronng View Post
    i second that opinion
