Originally Posted by xtat1k my dc2 leaks as well not sure where its coming from. anybody know? Tailight gaskets. Easy way to fix it, open boot and apply tape to the slot between the body and the tailight, all the way across.
Andrew Foy Imaging. FFamily DownshiftAus.com Honda Part Numbers <- Click here
Originally Posted by lil_foy Tailight gaskets. Easy way to fix it, open boot and apply tape to the slot between the body and the tailight, all the way across. you may get water inside the tail light itself if you do that. If you're skilled you can cut a new piece of rubber/foam using the original as a template, or you can get them from honda/wrekcers.
Originally Posted by JasonGilholme you may get water inside the tail light itself if you do that. If you're skilled you can cut a new piece of rubber/foam using the original as a template, or you can get them from honda/wrekcers. I dont really see how really? I'm sure the sealing on outside edge of the tailight is adiquate.
