Hey guys I picked up an entire 4WS system from a local junkyard for pretty cheap and this past summer installed everything on my car. I got everything working except I am getting a code 20 whenever I turn the steering wheel in one direction. I have tried everything in the book to try and fix this thing and cannot figure out the problem. I have double checked my wiring and I know it's right. I took it to the Honda Dealership and they tried to fix it and they couldn't figure it out. I was charged $200 on top of that too. They tried telling me I had a bad 4WS ECU and I know I don't because I have tested this system out with 2 other ECU's. I have the shop manual which helped me install this whole thing. After running down the list on code 20 in the manual, I got to the bottom where it asks me to perform the neutral check. Problem is, when I pull the e-brake and try to run the check, I get code 20 which blocks me from even getting into diagnostic mode.
If anyone has ever done this install or might know where my problem might be, your help would be highly appreciated!
Thanks
Matt
