Have you ever taken a drive then opened your hood and felt a big gash of hot air just rise to your face? do you ever wonder where it goes and thought that it would just be stuck in there? well heres a solution that could let the heat escape. It can also be used for all sorts of purposes where you need to keep the engine temperature down.
It should probaly only ever be used on tracks and off road, as doing this could void ur insurance and could be dangerous.
Aim:Cheap way to let the hot air escape from the engine bay.
Required:
4 threaded hex bolts(from supercheap)
40-50 washers(from bunnings)
Steps:
1. Remove one of the bolts on your hood hinge, connected to the hood, then go down to supercheap or any auto store which sells bolts for cars. You will need to buy at least 4 bolts, same thread but twice as long or so, depending how much you want your hood to lift.
THen drive to bunning and buy alot of washers which will fit your bolts.
2. after arriving at home, grab a mate to help you support the hood while you undo both the bolts on one side of your hinge.
3. replace the lower bolt with the new longer one and stick around 8 or so washers in there.
then replace the upper bolt and stick around 5 washers in there, there tighten it all up.
Pic:
4. do the same step 3 to the other side.
5. slowly open and close the hood to see if there are any obstacles. if there isnt, then its all good. If there is, then you gotta adjust the amount of washers you used.
Other comments: after taking a drive you can feel the hot air escaping from the gaps of the hood. so, it must be working
Before:
After:
