25-09-2012 08:01 PM
#13765
Originally Posted by Symphorced
What parts are you after Matt? I got sideskirts if you need.
I got some oem engine mounts as well lol.
25-09-2012 08:36 PM
#13766
Lol i got some stock suspension, intake, rear swaybar etc
AKA: The Spaniard! +1 Rep me if you find my posts useful.
25-09-2012 09:15 PM
#13767
Originally Posted by butterfingers
UNA91 clear your inbox got something to ask you thanks
Inbox cleared, took me ages to find where the delete button was lol...
Anyway, problem: My dash water temp sensor is not 'centered' when the car is fully heated up. It gets near, but leans more towards the cool side and never moves, unless of course the car has cooled down.
I also notice my aftermarket water temp sensor reads a little low, around 65-70c when moving and slowly crawls to 80c when stopped. Most other DC5r (judging by same K20 variant) averages around 80-90c, as well as my friends EP3.
I'm not sure if it's a stuck themostat or the OEM temp sensor going bad, my guess is the thermostat since my the Prosport gauge also reads a low temp. Any thoughts?
vtak + jrsc = bwwaaaahinneeeee
IF GUNS don't kill people, people kill people does that mean that toasters don't toast toast, toast toast toast?
25-09-2012 09:48 PM
#13768
Originally Posted by bluey45
Maybe check with dede at top one. If I remember he had a EP3 wreck in his workshop.
Yeah that wreck sitting at dedy's belong bigbaby0223, most of it is gone depending on what your after, as them fl hid lights are gone, in bought the te37 and his sard hi flow cat is gone as well, he has the car listed on gum tree
I let my Mrs hit Vtec, Maybe you should too!
25-09-2012 10:09 PM
#13769
UNA91:
My thermo sits on that same exact spot, I went up to half way on a track day but normal driving thats where it sits.
25-09-2012 11:28 PM
#13770
Originally Posted by JDM EP3
UNA91:
Mine just never moves any more higher, even if I push the car hard for a spirited drive or hoon the hell out of it lol >.> Not sure why the water temp reads low too, anyone have a aftermarket water gauge and wanna share their readings?
I've adjusted the gauge sensor position and topped up the fluid to the correct level and bled the system correctly
26-09-2012 04:31 AM
#13771
Thanks guys. I'm after a front bumper, not too fussed if its face lift or not
26-09-2012 08:52 AM
#13772
That's where they all sit dude
Its race car and your clearly not driving it hard enough lol
Take to the track and you'll see it go above half
161.4KW ATW Tuned By TODA
EG5 JDM B16A SiR-II TURBO
26-09-2012 09:49 AM
#13773
thrashing/spirited driving/hooning does not equal track
brakes chassis and engine are all being pushed to the limit.
vtecing and shifting at 8-8400rpm for a few seconds at a time puts no where near the amount of heat that track does, considering during track, your consistently at 5000rpm + for minutes at a times. not the same as giving it a hit down an empty road after a corner lol.
26-09-2012 11:11 AM
#13774
aright fair enough lol, btw where is the max line in the coolant reserve tank? I think I've got a leak at the bottom where it flows back into the radiator
26-09-2012 12:08 PM
#13775
At the track my genuine Defi gauge reads my water temp as being around the 110 degrees mark. Day to day driving, unless I sit in traffic after the car has been driven for a while, it won't ever reach 100 degrees.
26-09-2012 12:53 PM
#13776
Originally Posted by lemmiwinks
Thanks guys. I'm after a front bumper, not too fussed if its face lift or not. Also after the lower AC line
yeah dedy's got the front bumper (Pre facelift), its in a little bit of a scuffle nothing a good touch up wont fix but dont know about the lower AC line, as the whole engine was removed due to damage it suffered from the track day.
