fronts are; under the bonnet, under your car and inside the wheel arch where the guards are. that was for my dc2 but im guessing its the same as the 94 eg's. all you need is a 10mm and a phillips head.
rear bar; no idea. never done it before but have a look around you'll eventually find it. it's not that hard is it ?
i've taken out the fronts so many times it's not funny
front - 5 screws on the top of the bumper (right under the bonnet), 2 10mm bolts underneath and 1 more 10mm bolt inside each side of the front wheel arches...
rear - 1 10mm bolt inside each side of the rear wheel arches, then 2 underneath (i think they're only those) - not too sure about sedans...mine's a hatch
