Hi,
I have a 2nd hand turbo which is yet to be installed. The compressor wheel fin is bent as you can see
Can I leave this...or can I bend it back myself...or does a pro need to fix this by bending it back...or by replacing the wheel...and approximate costs?
Also there is black oil (I think engine oil) in the BOV.
I read on the net that it could be due to bad turbo seals or from the PCV...but the air intake arm does not have a nozzle for the PCV...so I don't think it's this. There appears to be no shaft play in the turbo...so what I CAN see seems fine.
Any suggestions is much appreciated.
