Results 1 to 3 of 3
    Nov 2007
    sydney
    s2k
    [help] starter motor bolt and top right bell housing bolt
    im currently replacing my clutch and im stuck on the top right right bell housing bolt and was wondering how to get clearance to remove it and also how to get into the inner starter motor bolt
    cheers
    Jun 2010
    Gold Coast
    s2000
    You should only have to remove the top starter motor bolt if I remember correctly. When doing so be careful not to bump you knock sensor. Easy way to blow $120.
    Nov 2007
    sydney
    s2k
    how did you go abouts removing the top start motor bolt? Im having difficulties getting clearance to remove the bolt
