at a guess - look under the passenger side kick panel , either LEFT or RIGHT hand side. (right next to the edge of the glovebox)
Look for a bright coloured rubber (blue or green) and there should be 2 plugs in it , one with 2 wires and the other with 3.
Take the 2 wire plug , run a piece of speaker wire or similar to short the service connector and check your dash light for the correct code
