Page 110 of 313 FirstFirst ... 1060100107108109110111112113120160210 ... LastLast
Results 1,309 to 1,320 of 3745
  1. #1309
    Apr 2009
    Adelaide
    DA9 Integra
    hey guys
    acura indicators should fit on honda right?
    i found clear indicators but couple of mates are telling me that the globe fittings are different...is this the case?.. i assumed that they would fit with out a problem..
    cheers
  2. #1310
    Jan 2007
    DA9
    they should fit, yes. sides and front, for that matter.
    Bought from: Taleb Tyres, scyt7e
  3. #1311
    Jan 2007
    DA9
    haha worst luck ever, just got word my trailing arm bushes need replacing. Got quoted $376 for genuine honda supplied and fitted though..
  4. #1312
    Oct 2007
    campbelltown
    Integra DA
    cluster
    im interested in getting the jdm vtec cluster for the da and just wanted to know if wiring will be an issue? whether it is OBD0 or OBD1 as my car is a 93 model with OBD1 wiring.
    thanks
  5. #1313
    Jan 2007
    CL9
    not sure about the vtec version of Jdm cluster but i have a non vtec version and the wires are all fine. plug and play.
    really should be fine, but if there is any form of vtec light on the cluster then u might have a problem as there will be no vtec signal wire on ure original harness.
    than again that problem is easily fixed.
    good luck,
    HCCM#23
    02 DC5 ITR
  6. #1314
    Sep 2005
    Perth
    DA9, eg, n360,
    yeh but the wire would prob just b missing on my eg i got the gl so its a carby one and the plugs r the same they just missing the wires
    it should fit and not be any hassles
  7. #1315
    Oct 2007
    campbelltown
    Integra DA
    kool thanks guys. so it wont matter what jdm cluster i get and i have to run an extra wire for vtec. at the moment there is no problem as the vtec engine light doesnt show up so shouldnt be any differrence when i get the jdm cluster, just plug and play as you mentioned?
  8. #1316
    Sep 2005
    Perth
    DA9, eg, n360,
    yeh is ur car vtec? if its not u dont need to run the wire it should work with out it all together
  9. #1317
    Oct 2007
    campbelltown
    Integra DA
    yeah ive got vtec. so there would be the wire already running through. i dont get any engine light come on.
  10. #1318
    I have a 92 JDM Vtec dash, it has climate control but no VTEC light, there is a funky one for the CAT, if its too hot when you stop the car, it indicates this, for some reason they think you will park on top of long dry grass and burn the car
    I am thinking to use this as the VTEC light, will post a diagram if i get round to it
    Every Day You Don't Practice, Is A Day You Get Worse
    (\__/)
    (='.'=) This is Bunny. Copy and paste bunny into your
    (")_(") signature to help him gain world domination.
  11. #1319
    Sep 2005
    Perth
    DA9, eg, n360,
    aw yeh maybe put a sticker over it or something then its looks like just a light instead of the vtec got any pics?
  12. #1320
    Mar 2004
    Audi TT 2.0T
    Quote Originally Posted by tseesinngwailo View Post
    ive used this light as a vtec light before...it does nothing otherwise
    maybe ill dig up some videos
    FFR33K - SOLD
    LSV73C - SOLD
    CW DC5R - SOLD
