guys im sellin an s200 and its been that long since i even thought about the thing that ive forgotten anything about it, main thing i want to know is, how can i tell what ecu its for, eg, 0bd1 etc, i bought it for a b16a so im assuming i got one for an obd1. any help is appreciated haha.
sounds odd bout the wheel man have u got oil in ur p/s?
ur second prob sounds like ur master cly might b buggered. u can try bleeding it but im pretty sure its stuffed
the master cly has a tandem setup inside so it runs 2 clyinders for the braking system so 1 goes to the front 1 for the rear if one fails you will loose half of ur braking system sometimes they bypass inbetween each other. so try bleeding it otherwise replace the master cly... unless u can see it leaking somewhere again unless being there its hard to say...
ive had one i did for a mate his would go straight to the floor sometimes but would come good if he kept pumping it back.
