I've used two types of front end kits in my CB. The Ingalls anchor bolt kit and Ingalls adjustable ball joint kit. Both seem to be made well. Both are a pain to adjust. Especially if you have coilovers that won't let the suspension droop when you lift the car.
The main problem when you start using a camber kit is hitting the upper control arms, depending how low you are. If you use the anchor bolt one you can adjust it so that it doesn't hit. If you use the ball joint kit it adds height to the arm and if it is going to hit it will hit no matter what camber you set it to.
By 'anchor bolt one' do you mean the replacement upper wishbone version? The only Ingalls kit I can find on flea-bay is the ball joint replacement one. I'm not planning to go that low, only about an inch or so. I don't like scraping on anything
If you're only lowering an inch or so then I wouldn't even bother. There is only one complete replacement wishbone that I've seen for the accords. Can't remember the brand, but it was some obscure thing and the only person I saw that bought one it broke.
i've got the following for my ride.. but not installed yet (don't have time). i've got about -3 degrees camber on all corners... i'll let you know how they go...
Yeah i am thinking of buying one pretty soon.
Will have my coilovers in within a week, and that should lower 2inch+ so i think i may need one pretty soon, as I have 215/35/18 kumho tyres which are definately not cheap for all 4 corners.
Gas up the Vtec for you tonight and baby you can go wherever you like.....
