yeah 22mm itr rear sway. ive got ek4 front which is 26mm i believe, but i think its possible to put an itr front sway on an ek, not 100% sure wats involved
i'm pretty sure front is fine, but back after my friend tried to put it on and it didn't fit we didn't bother with the ITR one again. THe exhaust hit the swaybar. He had an Ek1 hatch also.
ASR brace is a must for any ek with bigger than standard swaybars
for the front sway i think you need to change to itr lca's in order for it to work,
as for the rear, you would need a subframe brace, like the others have said. plus to make the itr rear sway fit, you need ek endlinks with the appropriate bushes (i.e ek9) as the itr bushes do not fit with ek bolts or get the ASR metal inserts which act like bushes to make the endlinks fit.
Green and Gold Ghetto EK4
OEM Front Lip, Ghetto Special CAI, ASR Brace, ITR Rear Sway, N+ Coilovers, X-Force Headers and TL Muffler, Custom B Pipe, type-r rear lip, OEM visors
