Aim ;
Mounting An Amp
Required ;
Sheet of board @ 1200x450x7mm
Jig-saw - if not ask bunnings to cut it @ the size should be free.
6 screws @ 24mm height
Screw driver
Reason ;
The reason for doing this is to help not leave any marks on the seats or any drilled holes
steps ;
1-
Have the Measurements of the Amp ready, Add 15mm to each side extra.
Eg- 350x270mm Add 15mm = 365x285mm
2-
Travel to Bunnings and purchase a sheet of board for about approximately $7 & ask them to cut the measurements that you already have or do it at home with a jigsaw ( should be free since its only two Cuts)
3-
Unlock you’re rear seat’s and lay it down flat
4-
Open up them little caps which is holding down the material covered behind the rear seats
5-
Place the sheet of board that you’ve Cut underneath the material to where you desire it to be stabled as (left/right) you’re choice.
6-
Lock them little caps back to position as the sheet of board is covered
7-
Get 2 screws and the screw driver & screw it down anywhere in the middle about 100mm’s appart throught the material + sheet of board to keep hold of the strength
8-
Put the Amp on top and centre it to your own likings
9-
Now mount the Amp with the 4 screws to the hole’s given on the Amp
10-
Once that’s done Lift the Rear seats back up and Lock it in.. FINISHED
. . . . . . . . . . Own Amp Mounting . . . . . . . . . .
