Results 1 to 8 of 8
Hybrid View
    Newcomer Array
    Jan 2008
    Civic 1.6 FD4
    Hose between PCV valve & intake manifold
    Anybody knows where is the Hose between PCV valve & intake manifold on a R18a engine???
    Dec 2007
    perth
    fd1
    look directly on top of the throttle body (back of the engine) and you will see two thin pipes that are on top of each other.
    edit: actually here it is :P
    2012 BMW S1000rr - 184whp, 9.733s @ 148.27mph - Quick enough!
    2006 Honda Civic - 101whp, 61s BBGL Short - When I need a bbt.
    Newcomer Array
    Jan 2008
    Civic 1.6 FD4
    Hi,
    Thanks for the reply. But i thought that the one u circled is the breather hose?? There should be another hose that connect between the PCV valve & the intake manifold (normally after the throttlebody). Am I right?? Or for R18a or R16a engine, theres no pcv hose??
    Quote Originally Posted by rk 86 wa View Post
    is that a simota intake in there? if im not wrong, which one is it? the carbon charger?
    ive been doing a lot of research in getting one of these
    how's the sound? and comparing to stock, a huge improvement in terms of hp?
    Newcomer Array
    Jan 2008
    Civic 1.6 FD4
    I was wondering is it the one shown in the pic??
    Dec 2007
    perth
    fd1
    yah sorry top one is breather
    isnt the one under the breather the one that connects to the pcv valve?
    btw what is it regarding if i may ask?
    Newcomer Array
    Jan 2008
    Civic 1.6 FD4
    The one underneath the breather hose is the coolant hose going into the throttlebody.
    I wanna ask about the pcv hose is because i wanted to install a oil catch tank myself. I try to find & find, trace & trace but still cannot locate where. This R16a engine (similar to R18a) is built such a way that the air intake manifold is way below the crankcase cover, making it difficult to find the pcv hose
  8. #8
    Dec 2007
    perth
    fd1
    ahh ok, lol!
    hmm actually ill do one better and ask a honda tech tomorrow when he is at work for ya :P
