Page 1 of 3 123 LastLast
Results 1 to 12 of 25
    D series vs b18cr compared
    Apart from the very obvious, is there much difference between the two motors in regards to stripping them and putting them together?
    is it necessary mate.
    i thought u are more HONDA educated than the spams u make!
    its a serious question, and i haven't torn down Honda engines, thats why i'm asking
    EDIT: i was asking more so about the block, not really concerned about the head...
    Nov 2004
    Syd
    wtf dude. are you serious?
    d series is a sohc (single cam) [most anyways, except for the si zc)
    b series vtec is a dohc (twin cam)
    tell me if theres a differences. cant believe you even ask such a question after q ball closed your 1st thread.
    Banned Array
    Dec 2004
    Shit-Kneez
    Suabaru > Honda
    Quote Originally Posted by defect View Post
    thx captain obvious.
    lol
    Nov 2005
    Adelaide
    XR6 Turbo
    You guys are fcukheads, you should read what he is actually asking..... In regards to assembly the heads would be quite different since B series has the whole VTEC system and plus the DOHC setup. However, the bottom ends would be pretty much the same AFAIK with only a few minor differences.
    ______________________
    B20VTEC Build Thread
    Quote Originally Posted by ZeForce View Post
    thank you
    i was asking about the bottom ends of both examples
    thanks for the captain obvious posts, i deal it out, i take it too .
    but yeah, stripping bottom ends, much of a difference?
    and putting it together?
  8. #8
    My 1st thread was created in response to all the how much and what should i do threads
    yes, that is obvious, what you're pointing out, but thats not what my question was aimed at
    learning how to strip down a motor and put it together again.
    i've done heads b4, so i'm not concerned about that side of thinfs.
    more concerned about the bottom ends, are they similar?
    if i strip the D, would it be the same as stripping the B18cr?
  9. #9
    D series and B series - almost exactly the same bottom end.
    Only difference is the head with the UPPER parts of the head with DOHC VTEC.
  10. #10
    Nov 2004
    Syd
    ahahah I should be called Captain Rock Obvious
    i know not to browse forums when I have just woken up!
  11. #11
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    bottom end of b series is far more superior than d series the crankshaft,oil pump,water pump, pistons, conrods etc .... all have been upgraded to be reliable and to be able handle revs up to 9000rpm
  12. #12
    Quote Originally Posted by 90LAN View Post
    not relevant to this thread.
    His question is about taking apart / reassembling. Both B and D series bottom ends are quite similar and no hassle between the two
