Page 1 of 3 123 LastLast
Results 1 to 12 of 31
    Nov 2006
    Brisbane
    Civic EG Si Hatchi
    4 Lug ITR '96 Spec Brake Swap
    would like to know if these would be a DIRECT bolt on to an EG with discs all round? would the front hub fit into the existing drive shaft? i have a D series engine, so im not totally sure if this is possible. would i need other things for this swap apart from: hubs, rotors, calipers, trailing arm?
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    straight swap mate
    Hey,
    Assuming you only want to swap rotors and calipers, read on. If it's a whole sussy swap, then ignore.
    96 ITR was 4x114mm PCD.
    Civic's have 4x100mm PCD.
    The reason the 96 ITR rotors are recommended is that you can re-drill them to 4x100mm without overlapping existing bolt holes.
    This preserves the rotor balance.
    original calipers won't fit, upgrade to ITR calipers and pads.
    Same applies when upgrading rear rotors, need new calipers.
    Rear upgrades can get fiddly with brakes hoses and hand brake cables.
    Everything is here:
    http://honda-tech.com/zerothread?id=1811368&page=1
    Nick.
    PS. 9CLP14S rear calipers are also found on Prelude's. Hint! Hint!. The caliper bracket however is slightly different and currently researching other differences.
    PPS. Mini2 rear rotors are 4x100, 64mm ID hub bore and 44mm rotor height. Civic is 61mm ID hub bore and 48mm rotor height from memory. Might be able to get away with just a hub 61mm ID 64mm OD hub-ring. Will post more when more info is available.
    PPPS. no need to swap hubs, uprights and trailing arms unless you want five lug setup.
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    he's changing the hub its not gonna matter
    Quote Originally Posted by nd55 View Post
    I thought 96 ITR was 4x114mm PCD.
    original calipers won't fit, Upgrade to ITR calipers and pads.
    Everything is here:
    Nick.
    PPS. Mini2 rear rotors are 4x100, 64mm ID hub bore. Might be able to get away with just a hub 61mm ID 64mm hub-ring. Will post more when more info is available.
    Evo IX - THE FINAL EVOLUTION
    Account Disabled Array
    Sep 2004
    Sydney
    CT9A
    Quote Originally Posted by riruiz_88 View Post
    Will bolt up. Just re-use the stock hand brake cable. Shafts will slide in.
    Nov 2006
    Brisbane
    Civic EG Si Hatchi
    wicked i thought since havin a D series it wouldnt but all good. would i need a wheel alignment and wheel balanced done as well since im gonna be needin new wheels?
    Banned Array
    Dec 2004
    Shit-Kneez
    Suabaru > Honda
    u always get that stuff done when u change wheels don't ya ?
    good luck man.
  8. #8
    Ozhonda Trader Array
    Aug 2003
    Sydney.
    EGK24A
    Wheel alignment is needed.
    Any time when you change tyres on your wheels it needs to be balanced.
    JDMyard Pty Ltd
    25 / 317-321 Woodpark Rd , Smithfield , NSW 2164. Contact : 02 97572364
    Email : yonas@jdmyard.com , Facebook : http://www.facebook.com/JDMYard
    www.JDMyard.com
  9. #9
    Nov 2006
    Brisbane
    Civic EG Si Hatchi
    thanks for the answers, are the rotors and calipers the same size as the aus DC2R? what is the measurement of the disc?
  10. #10
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    nope same as dc2/ek4/eg6
  11. #11
    May 2005
    Syd West
    ek4lyf
    262mm
    CEE CEE DUB U
  12. #12
    Nov 2006
    Brisbane
    Civic EG Si Hatchi
    dosnt the EG come standard with 262mm, well the Si?
