Results 1 to 12 of 13
    Aug 2006
    Noosa QLD
    ED Civic
    Biggest Wheel size ?
    Whats the biggest mags that will fit on an ek/ ej8 coupe without it scrubbing ? Will 18's fit ?
    thanks.
    Oct 2006
    DC5 Type S 05
    17's/18's is where it starts to get to scrub territory depending on how sagged your suspension is from age and how low your car is. On stock height and down to about 1 inch lowered you can get away with 17's, with 18's you will probably have to roll the gaurds.and if your car is lower the problem gets worse obviously
    CHEAPEST PRO DIY
    Aug 2006
    Noosa QLD
    ED Civic
    Quote Originally Posted by teh_mechanic View Post
    Yeah, my car is lowed about one inch atm on 16's
    Banned Array
    Mar 2008
    Nothing... Yet!!!11!!
    put 22's so u wont move its much better
    Mar 2008
    Perth
    Honda Civic 1997 GLI
    17 will definately fit
    Im curently running 17's with 205/40/r17 tyres on oringinal stock sus on a 1997 civic gli (EK), no rubbing at all even with hard cornering or cornering at full lock
    things are pretty tight tho so i dont know about 18's may need to roll guards or somthing.
    Hope that helps
    Im new here... Play nice...
    Quote Originally Posted by kyobibi View Post
    lambo doors are nice....do jdm make lambo doors?
    Ninja turtle Array
    Chloe
    It's the tyre/rim width and overall rolling diameter that determines scrubbing. Not the rim diameter.
    Stocky CL9 - 1:17.2
    Aug 2006
    murarrie
    EG Si Hatchie
    18's a piece of cake on my old ek hatch. i had very stiff suspension. after rolling my guards cutting away plenty of splash guard i had no scrubbing
    Is this the end of my car modding days? Buying a house says so...
    Jun 2006
    WA
    EG+CL9
    i wouldnt go bigger than 17" on hondas
    loose too many benefits
    Mar 2008
    Perth
    Quote Originally Posted by TheSaint View Post
    Yeh tis true, just made the switch to 17's cornering is nice (over the stockies with crappy tires) but acceleration has gone out the window, which is good in a way, cure for the lead foot which as a p plater and uni student i really cant afford
    If your going for show then i can tell you that 205/40/R17 on 17x7 rims will work as that is my current setup... this is with everything else stock but as your only lowered 1inch im pretty sure it will still be ok... there is not alot of room there on the inside on my car so wider rims would be hard and due to the car being lower i think you will have problems with your guards wanting to eat your tires.
    My honest advice is to not go any bigger than 17's, unless you are prepared to do some extra work, and if your looking for performance then 17's is not the way to go, some light 15's is probably your best bet IMO
    Very true hence listing tire size as well, hehe it don't matter how small rims you got 4wd tires are not going to fit without some serious work :P hey at least you could say your unique.
    As said previously, it all depends on how much effort your willing to go to...
    Aug 2006
    murarrie
    EG Si Hatchie
    18x7.5 with 215/35 tyres was what was on mine and it was fine. +45 offset. wouldn't recommend it. 16" race lightweights FTW put the money saved into better tyres.
    Jun 2006
    WA
    EG+CL9
    Jun 2007
    SyDNey
    EK Ferio Sedan
    I have 19"x8 on My EK sedan .. rolled guard and cut the splash guard.
    rubbing little bit if i got full passengers.
