Im pretty sure just disconnecting the negative terminal on the battery, resets the ecu too. because it cuts power off to everything.. unless the fuse box holds a charge...
well I know mine works because I did it last week and it def the safest way to do it.
+ its good to reset the ECU whenever you change engine/performance stuff this way the engine gets a chance to adapt to the mods you made and run at its max
