Ok my budget would be about $800 including mono. Depends, maybe about $300 - 400 on sub and the rest on the mono. Should i spend more on the sub or mono? A 300WRMS sub should be enough in a eg yeah?
ok look, i didnt say what amp to buy i only said the pdx is a good amp "its called advise" He said his budget is about $800 for an amp and sub, in the same sentence he said should i spend more for an amp and sub. leave it at that
= First Production Company To Produce 100HP Per Litre NA
If you want a cheap subwoofer that pumps like the big guys, look for an Adire Shiva (value) or Brahma (performance). These subs are not well known but they are very respected and cheap!
I paid like $300 for my Shiva, and it was 10x better than the more expensive Cerwin Vega I had previously.
Google "Adire Shive" and "Adire Brahma" and you'll see what I mean.
Unfortunately the company has closed down so it'll be hard to source one of these subs. However you should be able to find one, on ebay or other online places.
yer $3-400 on a sub & the rest to a amp is what id do if i were you.
personally id spend more on the amp. headroom is always betta than pushing the limits
300 rms is plenty. depending on how its tuned, installed, what box, etc, and of course what you're expecting out of it. dont expect to win any comps tho.
honestly your budget isnt alot but you've definately got enough for a decent combo. hmmm sub & amp suggestions..
sub: $3-400 ones that come to mind are:
alpine type r
dd (digital designs) '15' or '25 series
boston acoustics g2
image dynamics
treo
adire
jl
orion
dw if you havnt heard of some of these brands, theyre all very respectable & well-made
amp: if you're spending 400 on a sub then the other 400 wont get you any special monos.. it may be enough for the more 'mainstream' branded monos but the ones im thinkin about are 600+.. you might have to use a bridged 2chan instead.
Its all about BOX.... as long as u get a reasonable woofer... if u have the rite box it will Crank... i did 151.6 db with 2 $300 subs in the jazz... and did 149.1db with the 12" Option Audio Pro 12"... i think there retail is 399.. but i have a few new ones i can let go alot cheaper then that if u want.. and as for box design i have an EG box design that Cranks
Originally Posted by AZ51LK
when bruce banner gets angry and loses it, he turns into the incedible hulk...
...when the incredible hulk gets f*ckin pissed off and loses it, he turns into amurray
yeah, i meant exactly what rice_civic mentioned in the previous post. I wanna spend $800 all up, so spend like $300 on a sub then the rest ($500) on the amp or spend more on the sub and less on the amp?
