Yes these batterys are good for that little less engine strain caused bu the altenator but this is good ONLY for a run or two down the 1/4, One thing not addressed above is current draw,You can have a battery that starts on 16 volts and lowers so theoreticly it will be able to run the engine for longer but that may not be true, from experience with batteries and stereos. you can use a 12v battery with a very high reserve capacity and it will last for a very long time with a sustained voltage, just my two cents
= First Production Company To Produce 100HP Per Litre NA
