my mate jsut busted his h22a knock sensor just wondering if b series knock sensor are interchangeable with H series ? thanks
yep, same shit, you can even use k20,k24 knock sensors, but u have to change the connector, im using the k24 kock sensor because i couldnt find b series knock sensor. Works the same.
as above the knock compensation is adjusted by the knock PCB in the ECU. dont overtighten the sensor.
hi bud definitely have done before most hondas same EGJOE
