one's a + input, the other + is the output..the input + you wire to the battery (power source).the output + is what you wire to your stereo, and you have to put a wire to a ground point from
the -.
that one's for amps, not head units like the one I posted a pic of. It should have instructions telling you what connector the input is and what connector the output is. But it will go in-line on the power cable to your amp, not your head unit
Will be hopfully installing tomolo after work, n I 'll c how I go wit it.
When I bought the suppressor from Jaycar, the saleperson said if this component doesn't fully fix the problem, then I might have to get another suppressor the connect to the da headunit?
the best one to get is a supressor that connects to the rca to the amp.....if will take all the whining and static off but you will loss at lease half you mid bass
