if your wondering what a check valve is its a one way valve. like you can blow throught it but not suck.
they use them inline with the MAP sensor so it doesnt see positive pressure.
when my car shift from vac to boost... is crap .. will check valve do it? to make the transitions better?
ohh... where can i get them?
*noob here
There are heaps of them available on ebay US. But apparently a 2 or 3 bar map sensor is a much better option.
Someone( friend of a friend) fixed mine but I have no idea how he did it. My turbo EK still has factory ECU and drives normal. Engine light still comes on though.
A check valve will allow your ecu not see boost pressure on the map sensor, hence allow you to run boost without encountering cel limp mode.
You can buy a cheap check valve from your aquarium shop <$3.. They use it on the air pumps to stop water/air going the wrong way. If you want a heavy duty version use the ones they put in line with your vacuum feed for your brake booster.
check valves pretty much used to bleeds the boosted air so that the map sensor doesnt throw u a engine check light. and u would probably notice the car runs like shit wen this happens. make one urself, its not that hard.
u'll be able to drive underboost forever without the light coming on, its only when u hits about 1psi or 2psi of boost is wen the ecu will throw u the light
i get the light after about 10mins of driving off boost, or about 3-4min after of hittin full boost. but it doesnt effect the performance of anything, car runs fine.i was told to change my stock map sensor to fix the light .
