Hi Guys,
I have a problem with my 01 S2k's engine light turning on. The engine light turns on and then the car starts idling funny/reving up and down 3-5 or so bars on the cluster.
It starts when you put the key into the ignition and it you get those few beeps a few times then stops, immediately the engine light turns on.
If i let the car sit there and idle for a 10 minutes or so, turn it off and then back on, the engine light goes away and the car is 100% again... Another way to fix the problem sometimes is to just drive it for about 5 minutes or so, then pull over and turn the car off/on again and the problem clears. When i do the second option though its quite an unpleasant ride, the car feels jerky and just does not drive right at ALL, quite undriveable actually.
I noticed that the problem usually happens when the car is cold, Generally occurring in the morning or at night...From the way my problem clears i'm kinda suspecting some kind of sensor is stuffed and is being affected by the cold and needs to be warmed up.. I have only owned the car since December and never had this problem until these last couple of weeks as the weather has gotten colder...The previous owner says he has never had a problem...
I took the car to Honda in Warrick Farm for my major 80k service on Monday and described the problem to them and asked them to check it out. They hooked up the computer to it but could not find any issues, they did the major service and a full checkup and could not find the problem...
The only other thing i can think of is to park it there at Honda overnight and have someone observe the problem in the morning....but this is a last resort as i work 6 days a week and cant go without my car.
Has anyone had a similar issue or any ideas on what could be causing this strange problem ? Any help would be greatly appreciated.
cheers,
