have you checked that the mini pump is actually working by disconnecting the water lines from the nozzle?
using a pin usually does the trick cleaning those things...
Originally Posted by Slow96GSR
If 1 person has had bad luck with a product don’t condemn it until you yourself have tested it. Now if 10 pros have tried it and it sucked then I would trust their opinion.
just get some from pick n payless or those 3 nozzle ones from ebay or those wide spray ones from autobarn
