Results 13 to 24 of 30
    Old Honda injectors make noise, it's a fact. Tick tick tick tick tick tick tick get used to it ha ha
    Mar 2008
    brisbane
    panda!
    mine's quite new 35000, just tick cause of too much reving lol. surprised if the injectors would clogg this early
    Aug 2007
    Choo Choo shoe.
    Quote Originally Posted by fitvpower View Post
    its ure tappets dude -.-"
    read previous comments.
    hondas usually get tappet recheck at 40k's
    you have 35000.
    and a ticking noise.
    it kinda screams. hey my tappets need adjusting. since you fit in the kilometre mark and complaint description.
    go to a "good mechanic place" as some have said or go to a dealer.
    dont diy if you dont know whats involved in taking a rocker cover off.
    head gaskets are for the cylinder head.
    thats where the cams sit.
    and on that .. are the rockers.
    the rocker cover.. covers all that.
    fork out a few dollars on getting it fixed.
    rather than trying to do it yourself and spending money on broken parts.
    an engine wont be quiet quiet.
    only quiet engine is hybrid.
    a normal engine has fans, alternators, and a/c rotating ..
    but thats out of the topic.
    in engine wise.
    you have the injectors, sparks, combustion, exhaust resonance, induction, and probably a bit more.
    but youll never get a silent engine.
    and a "tick" isnt always from one thing.
    and if you want it fixed. start with the most common/basic. in this case .. tappets.
    =] have fun.
  4. #16
    Mar 2008
    brisbane
    panda!
    cheers jai, ur right i should take it to a mechanic, having adjusted urs, could you give me a price quote for a tappet readjustment?.
    btw. nice lights on ur eg, looks like a prelude
  5. #17
    Ninja turtle Array
    Chloe
    Quote Originally Posted by OMG.JAI xD View Post
    you have 35000.
    Do you think this engine in this video needs to have the valve clearance checked? http://www.youtube.com/watch?v=4K3dky-zs1Y
    Stocky CL9 - 1:17.2
  6. #18
    Mar 2008
    brisbane
    panda!
    hmmm, aaronng, so is that engine in the vid need readjusting, my engine does NOT sound like that. there is sound but not that pronounced. so is mine a valve problem or something else
  7. #19
    Ninja turtle Array
    Chloe
    Something else. Because in that vid is my car. I brought it to the dealer for a valve adjustment, they took it apart and found that everything was still good. The valve clearance was still within spec and there was nothing to adjust! It was the injectors making that tapping sound. When your valve clearance needs adjusting, the engine will sound like a diesel. It doesn't "tap".
    Stocky CL9 - 1:17.2
  8. #20
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    i adjusted my tappets and the engine was quieter, the tapping noised reduced quite abit
    Evo IX - THE FINAL EVOLUTION
  9. #21
    Mar 2008
    brisbane
    panda!
    well here's the video <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/uxHK2di3adM"> </param> <embed src="http://www.youtube.com/v/uxHK2di3adM" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
  10. #22
    Mar 2008
    brisbane
    panda!
    http://www.youtube.com/watch?v=uxHK2di3adM
    look at 6 seconds, and onwards, looks like the sound is comming from that region. i'm too noob to be exact. any of you teckies got ne ideas?????
  11. #23
    Thumbs up
    Quote Originally Posted by onlykillzz View Post
    don't stress out yet, it could be as simple as a loose bolt get a compression test done you can by a tester for around $60 at repco or a supercheap
    looks like this:
    and follow this diy
    comp test
    if you get good numbers then you no its not your pistons or valves and you can move on from there.
    (it could also be your tray has a broken tooth on one of the cogs
    +1 i agree for a comp test
  12. #24
    Ninja turtle Array
    Chloe
    Sounds a bit like my engine. Except that mine is louder.
    Stocky CL9 - 1:17.2
