depends what headlights
if its stock replacements with reflectors, you could probably just adjust it via the adjustment screws
projectors are probably the same story unless they have cutoff plates(i.e. hid projectors) which will probably require modifications to get the correct cutoff angle
projectors you have to open up and swithc the cut offs over
and standard headlights not a good idea to use LHD ones... they shine higher on
the RIGHT hand side to reflect signs where as RHD ones shine higher on the
LEFT hand side to reflect signs...
true.. i got some lhd ones.. no matter how much you adjust them it's shit
Originally Posted by Slow96GSR
If 1 person has had bad luck with a product don’t condemn it until you yourself have tested it. Now if 10 pros have tried it and it sucked then I would trust their opinion.
tailights are all good yup yup, if you got sedan try to track down
sedan taillights they might differ from the coupes slightly... i dunno... as
same with the hatch of course...
depends what tail lights too
altezza's from the states might have a red lens/cover thingo for the blinker which you'd get defected for over here, so you'd either have to replace it with an orange blinker or somehow make it fade to the point where its orange
if u get green bulbs, it will blink orange with the red lens. i had it with mine. no big deal. if the tails are smoked, just bare in mind that ur lights will not be as bright...cops might notice it...but depends how smoked they are.
Originally Posted by 1FULSIKBOY2C23Q2NT2SXI4U
only be putting the goood shizzle in dis dizzle, for grizzle mizzle!
