Gearbox MTF b18c2
Any idea where about to pour MTF Gearbox fluid into a b18c2, cant find the hole,
atm ive Drained the Gearbox fluid at the bottom of the car but dont know where to pour Fluid back in.
tryd searching .. cant find any for that engine
should be further up, just look around you'd be able to find it soon enough
Why hello there
is there another Entry where you can pour gearbox oil ?
besides the one at the bottom of the car.
yes one further up on the gearbox.... it's another one the same as the lower one.. exactly the same.
Why hello there
my m8 poured it through there , its a Bolt Below the Intake Arm directly ontop of the Gearbox ?.. is that it?
juss checking coz im worried he poured it into something else.
just check the drain bolts, if they are the same then a-ok.
sounds like it though
Why hello there
ill get a pic hold up
2 possibilities
he either poured it into the VSS,which u would prob recognise by the wiring plug attached to it,so oil did go into gearbox,no probs
or he poured it in thru the bolt holding the reverse gear shaft,oil still goes into gearbox ok,but just make sure bolt went back in properly all the way & make sure u still got reverse gear,lol.
like i said,it all went into the gearbox,but that bolt holds your reverse idler shaft in,not the best plan of attack,take the VSS out next time,the black thing just to the right of it in those pics with the wiring plug on it,but even then make sure u dont lose the small pin that will come out as well.
or just do it the proper way & fill from the bolt thats in the side just above the drain bolt,u should of filled it till it was just started pouring out the fill hole anyway,how did u know how much to put in or did u just measure it?
i just syringe it in thru the fill bolt,takes a little longer but hey,im in no hurry.
oh btw have u tried reverse gear in ur car yet,lol?
that's new, how did you know how much to pour in ?
Why hello there
2.2 , well thats what said was recommended for my car
Yeah, reverse works fine
Thanks for the help.
