Results 1 to 9 of 9
    Dec 2006
    Perth
    DC2
    Konis on stock springs
    Hey has anyone got konis installed on stock springs, mines dc2 to be specific
    i was wondering if the springs were to be installed on the lowest perch on the konis, how much would it lower the car? i've searched but i cant find anything on this
    Mar 2006
    doorstop
    its something like 1 inch front & rear,maybe a little less on the back
    i should add,thats if your getting koni yellows
    Aug 2007
    Honda Civic Ferio 99
    by memory its 1.25 inches
    for a more accurate idea, just put a ruler on the perches and measure the drop or raise.
    i think for dc2:
    Front set, there are three perches and the middle perche is the stock height.
    Rear set, there is only two perche and the top one is the stock height
    Mar 2006
    doorstop
    2 on front,top stock
    3 on rear,middle stock
    Dec 2006
    Perth
    DC2
    yeah they are koni yellows, thanks guys
    Quote Originally Posted by JamB View Post
    so you can choose the amount of drop. From "around" stock height to alittle lower.
    Aug 2005
    GE8
    I have koni yellow with oem spring on my civic.
    On stock perch and still have a big gap on wheel.
    I'm not dropping my ride anyway. On it's softest setting, it's firm enough (for me). I notice dive/squat has been reduced significantly compare to oem dampers.
    a great mod...
    Would theses drop an ej8 to low if it already has king springs? been looking into this option to
    Aug 2005
    GE8
    yes.. you can go lower, like what crxer said.
    Koni yellow has 2 perches on front damper and 3 at the back.
    When you purchase them, koni use the top perch at the front and the middle perch at the back.
    Have a read on:
    http://www.ozhonda.com/forum/showthr...i+perch&page=2
    http://www.ozhonda.com/forum/showthr...ght=koni+perch
