Ok
Depending on what engine you want to put in (lets say a b18 because im unsure of which specific accord engine you are talking about) you will need to buy (to make it quick and simple)
-Hasport Mounts, Axles, conversion wiring (can buy this from hasport or wire everything up yourself) and most likely a shift linkage but you can probably use a ED linkage once again depending on the engine and GBOX
Here is a package you can buy take note its for the civics but i think it should be the same
http://www.hasport.com/products/mount_kits/avb1.htm (Confirm with hasport)
I believe the accords would use the civic mounts but its better to contact Hasport or whichever company you go with before ordering
You most likely will need a VSS cluster so depending on how lucky you are you may already have that (but worst case senario you need a integra cluster and you convert your current ones to run the VSS system)
If you have a complete half cut that will make things alot easier and you can probably use alot of the stuff from the half cut (and modify it to work with your car) instead of needing to buy it from hasport
As for how long its like asking how long a piece of string is
IMO If atm you have everything you need now and have all the necessary tools etc etc it can be done in a week
