127Kws is a good figure based on the modifications you have. I had to do more to get there, maybe my car was a weekend special.
Anyway, VAFCii is just an interceptor which allows you to adjust your VTEC cam opening as well as your A/F ratio. Having tested this as well as other interceptors, the Euro's ECU has the capability to relearn and overwrite the tune over time. I can happen in as little as a day or over 2-3 months (of both which I have experienced during the testing). The VAFCii is not good enough in constantly intercepting the signals to stop the ECU from relearning. In saying that, not ALL interceptors or piggyback are like that, there are good ones such as E and V Manage from Greddy which are capable of holding off the ECU from learning if not at a slower rate.
To the topic on adjusting the VTEC cam opening, each car is different and reacts differently to whatever modifications are put in place, even 2 same cars from the same production batch with the same modifications will react differently to tuning. Everytime I dyno tune the car with different or added modifications, my tuner finds that the VTEC engagement points are different each time, once we even found out that the stock engagement point was the most optimum for power and linear torque delivery.
As for your case, if your tuner is a competent one, whichever point he set the car for VTEC, you should trust his work.
