Results 1 to 12 of 12
    Oct 2005
    Syd
    Integra Type R
    Petrol companies probably done the dodgey!
    Hello,
    I filled up at the pumps at mobil on hume hwy lansvale now so long ago. After filling up the car, the car's idling was out of place. Its idling under 1000rpm at stand still, and when i hit the gas it theres a lag from 0-2000rpm. So i suspect dodgy fuel from the oil company. Either contaminated fuel or water addictives in the fuel. I need to get the fuel out to check it so i can flame Mobil
    Anyone ever experience this issue?
    Now does anyone have any ideas on how to take fuel out from the tank of a eg hatch?
    I tried using a tube and thread it into the tank. That doesnt work. I ve done some research and havent found what i was looking for.
    Help me out if you know something please.
    Regards Ken.
    mugen無限power
    Feb 2007
    Sydney
    08 Euro Lux 6MT
    How about going back to the same petrol station, same pump and fill it up in a container.
    08 Blk/Blk Accord Euro Luxury CL9 6MT / Full Silver Panel Trim / Full Modulo Kit / Sports Grill.
    For Sale: Accord Euro CL9 03-05 Front Euro-R Badge
    Account Disabled Array
    Jul 2005
    Pariaman, Indonesia
    Mitsubishi Colt TME
    he still has to get the shit fuel out nigra
    Oct 2005
    Syd
    Integra Type R
    Good idea, but i also want to take the fuel out and refill it with something else to be sure that its the fuel thats the problem.
    I filled up almost a full tank so i wont risk running a full tank of contaminated fuel.
    mugen無限power
    Jul 2005
    Pariaman, Indonesia
    Mitsubishi Colt TME
    get the workshop manual for your car from internets and see if there is a bolt you can undo.
    prime it out from the fuel rail...
    Oct 2005
    Syd
    Integra Type R
    have you got a diy link or anything teaserR?
    thanks!
    mugen無限power
  8. #8
    Aug 2007
    Perth
    EG Civic
    you guys are funny, there is a bolt at the bottom of the fuel tank, i think a 14mm or 17mm, get the car fairly level, undo and most the fuel should drain out.
    = First Production Company To Produce 100HP Per Litre NA
  9. #9
    Quote Originally Posted by B18cEG View Post
    ive never lookd under the fuel tank
    Quote Originally Posted by Sir_vtec View Post
    thanks!
    where the fuel enters the fuel rail... ive never done it before but its a method to get the fuel out...
  10. #10
    Oct 2005
    Syd
    Integra Type R
    Theres no bolt from under the tank.
    the only way im gonna probably flush it is with syphon method from where the fuel pump is inside the cabin or prime it at the fuel line prior to the fuel filter without cranking the engine. ***ken sucks Mobil
    Thanks for the help guys
    mugen無限power
  11. #11
    May 2006
    Brisbane
    380GT,XTrailSTR
    there is a bolt... look around under the boot area...
    take you forever and a day using the fuel pump prime method....
    Quote Originally Posted by Slow96GSR
    If 1 person has had bad luck with a product don’t condemn it until you yourself have tested it. Now if 10 pros have tried it and it sucked then I would trust their opinion.
  12. #12
    Oct 2005
    Syd
    Integra Type R
    LOL thanks for confirming dsp...
    mugen無限power
