Anybody know how to add xtra relay for headlights?? itll be nice if there a diagram for it?
I heard tht if you got a hi wattage headlights you have to add extra relay is tht true?
^^answer to second question is a no, you would just need to upgrade the plugs to cope with the extra heat.
no need for diagram and relay, theres different ones for different applications, you have to understand what you need each for.
an example of when you'd use one is if your hooking up foglights.
i do have a diagram for my del sol though... to swap my high beams over into the housing instead of from the circle lights... if anyone with a Del Sol wants it PM me.
Originally Posted by Slow96GSR
If 1 person has had bad luck with a product don’t condemn it until you yourself have tested it. Now if 10 pros have tried it and it sucked then I would trust their opinion.
