ill post pics of the ride height of my car aswell on the mono flex can go prettyy low without affecting the springs you dont get that low car bounce like you do with other coils/springs
so mikey, what coilovers did you end up getting? lol
I'd rather walk way from something saying "that was too hard" than walk away saying "that was too easy"
***GREEK PRIDE METER***
█████████████████████ 100%
hahaha... i've been on the cumberland highway from end to end.. and the section of hume hwy in yagoona.. west bound.. comfortable.. well compared to my tein ha's which was spine jolting.
ive got N+ in my EK. lowers the car to a decent height, more than tein SS i believe. can be set quite soft or rock hard. if ur worried about body roll invest in sway bars. coilovers wont fix it.
du if u can go from parra rd from auburn to flemington with the coilovers that would be nice
ill take up that challenge
my coil overs took out heaps of the body roll.. more noticeable comparing them to my 22mm rsb setup.
springs + standard shocks = not much of a difference in body roll
springs + standard shocks + 22mm rsb = a big change.. less body roll
tein HA + 22mm rsb = same shit really abit more stiff but similiar body roll
tein monoflex + 22mm rsb = ALOT less body roll more noticeable once the new coil overs were installed less stiff.. spring rate is perfect..
so pretty much if you find a very good set of coils.. i find upgrading the sway to a 22mm one wouldn't be very noticeable.
all in all i reckon if i took outmy sway bar there wouldnt be much of a change..
and ive played around with the height settings aswell.. from normal hieght to very low not much of a difference in handling.
