Results 1 to 5 of 5
    Sep 2003
    imma be where im @...
    1996 EK1 Civic Vti[R.I.P]
    This may have posted up or asked before...
    ok, wen i start up my car, i can hear like a slight knocking noise, but when i put the clutch in, it goes away, then when i take the clutch out it comes back....
    wat could it be?
    cv joints, drive shaft?
    Needs more time... Array
    Aug 2003
    Sydney
    Blog Entries
    12
    If this is happening when you are NOT moving then its not your CV joints or drive shafts.
    Sounds more like a clutch/gearbox related problem to me.
    Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
    Like wynode said, definitely not cv joints/drive-shaft problems.
    Aug 2003
    Sydney
    Blog Entries
    12
    When you put the clutch in / take it out are you in neutral?
    Cause if you are, then its possible there's aproblem with the clutch IE maybe one of the springs from the plate have come out.
    Sep 2003
    yeah it only happens in neutral... the clutch needs to be checked out anyway, also wen i gear down its sounds yuck... i dunno... thanks for the input fellaz
