grab skunk2's
bumpy ass. makes u fall asleep.
ill post pics of my car when weather is cleard up.
ive got stockies on though lol so its not a problem.
but the car is fkn dropped.
oh and not to mention i have stock shockies on =]
gosta grab the shocks sum otha time.
my prelude is lowered on king lows...
ride has been good for a month. it's just slightly bumpier than stock. i've got a 2 finger gap all around with stock 16" rims.
should i expect it to be shocking in another 6 months or so?
so when you say sag are you saying it will keep on sagging over the years til your car is 1cm off the ground? of course no one will let it get that bad...but you know what i mean.
you make it sound so bad...while other people say it's good value and stuff like that lol
so basically kings lows drop around 3.5cm...the really low ones drop like 5-6cm i think
ive got kings with 205/40R17's, dont scrub at all, if you have a bigger tyre ie: 215/45
you will scrub.... i tried putting them on the rear and it scrubbed like hell with no-one in the back!!.... as long as you have 205/40's you should be fine, hope this helps........
my car is on air suspension and basically sits on the ground on 18's. As long as you roll the rear guards you will be fine. If you want to slam the crap out of it then you will have to cut out the front plastic guards and get a hammer and bend the the metal seem in which is at the top of the guard where the quarter panel and chassis meet. There is also a bolt that is holding a part of the abs system on in the drivers side guard that you will need to take out and hammer in flat as this will rub on your tyre.
