Changing Rear engine mount
Hi Guys
Just wondering what is the easiest way to remove the rear engine mount on a B series Integra DA9 or even generally on a b series engine, i was having a little fiddle with it myself but couldnt get far without making things complex for myself
MTR - Mad Turk Racing
DA9 LS/Vtec V2,145.8kw ATW V2,PB 13.409@107mph 2.299 60ft.... 4.5 year old r888's
DYNO DAVE TUNED
Like a Post you See then hit me, PQ+
yeah i got the same prob its a B*tch to get to, i still haven't don mine for the same reason
Evo IX - THE FINAL EVOLUTION
unfortunately theres no easy way to go around it
just gotta keep removing stuff that gets in your way
took more time wiggling the mount out and wiggling a new one in than it did bolting everything off and back up again
If you're to remove the whole mount, I think youre gonna have to lift the motor out somewhat... partially if not all out.
Prolly best to put the car on jackstands, partially hoist the motor up, and then get at the rear mount from underneath the car.
Tom says: "Now remember kids, offsets are like women... they are best in their teens."
funnily enough i was able to remove the rear mount from an ek4 by just removing the whole intake, battery+bracket and disconnecting some hoses here and there armed with a lot of patience i got the bastard out eventually
Shit, the mount, not the mount point LOL... ok my bad.
Disregard the hoisting out part...
Yeh, as vinnY has said, either remove shit from the top, or jack it up and go from underneath.
Theyre both pretty much as annoying as each other
Green block gangster
Array
just unbolt the rear braket from the block and gearbox and from the mount, then undo the mount from then K frame, and wiggle it out.
Its realy not that Hard
Yea looks like i have to start removing things i didnt want to, ill try tonight and see how i go.
DYNO DAVE TUNED
just wondering will this affect wheel alingement?
Was able to remove the rear engine mount, i had to drop the rear cross member abit so i can access the bolts, its a job that requires alot of patience as the bolts take there time to loosen, now comes the hard part, putting it back on.
DYNO DAVE TUNED
good luck getting it back in man
i so don't envy you hehe
