With regards to the b16a2 engine coming out of a 96 vtir, not particularly sure if you have your info right there as those cars came with the b18 engine. Any way you can find out which car chassis it came out of EG, EK Civic?
Did the b16a2 engine come with an ECU? It will indicate on the ECU which OBD version it is running. This will help you for plug and play running of your engine. (http://www.superhonda.com/tech/honda_ecu_codes.html)
Yours is 4 wire, just make sure you get the right plug (ie male or female - check your car first) and you should be fine.
Old vs new
Cool cool, thanks,
I heard its expensive to get it with the plug and I should get it without and just join the wires?
So there is only one O2 sensor on my car?
