Page 1 of 4 1234 LastLast
Results 1 to 12 of 40
    DIY : Compression testies :)
    Its that time of the month again....DIY JOBBY !
    Aim: To test the compression of a engine - that is , basically see the internal condition of piston rings , valves , valve seals etc. Handy when purchasing a second hand car or if you are just paranoid like myself
    Required: Car. atleast 2 hands - only one foot is needed though. Compression tester tool , and spark plug remover.
    Steps:
    1.
    Open bonnet. Pull out all spark leads , then use removing tool to take out all 4 spark plugs.
    2.
    Open fuse box in engine bay ( upper should be right corner) - take out the fuse marked ECU ( 15a i think ?) ( to disable the fuel and ignition)
    3. Place the compression tester tool into the 1st cylinder (any is ok) and tighten up. Either get a friend to hold it and read the reading OR leave it atop the engine bay. YOU MUST FOLLOW ALL STEPS IN THIS PHOTO....
    4. Jump into the cabin , apply WOT ( wide open throttle/ full throttle) and turn over the engine 6 times. Jump out , and read the top reading OR get ur associate to tell you the maximum psi reached. Record down and write the cylinder number/location.
    5. Simply repeat for each cylinder - once all recorded pack up in the opposite fashion , reinsert sparkplugs + leads, then reinstall the ECU fuse and away you go.
    Other comments
    Results of the compression test will vary engien to engine - but apparently the wanted norm is a MAXIMUM variation of 28 PSI between all 4 cylinders hot or cold .
    If there is a substantial change in PSI perhaps a bent valve might be to blame - or worn piston rings or even a bad head gasket.
    IF in doubt , take it to a professinal to get a leak-down test + more to find the source of crappy boost
    Thats it. Go honda
    Very good write up. . Do you know what the pressure should be for a B16a? like, what is good and what is bad.
    TVIS - Toyota VTEC imitation system
    Quote Originally Posted by revNhevN
    i have no idea - my totally stock d16a8 - pulled 220 psi ( quite high) - while HOT ( that is , with the car warmed up properly). So , im sure your car could pull a similar number.
    As long as each readout is within the 28 PSI range there shouldnt be a problem.
    TRAVDM Array
    BNE, Q
    Lots of Hondas
    cool write up ben, i should do this
    ur the diy king y0!
    oh wrd!
    Banned Array
    Aug 2004
    Adelaide
    Gen3 CRX
    yeah, just on this, ideally, the cyllinder pressures should not vary by greater than 5%.
    Excellent writeup
    Nov 2004
    MELBOURNE!
    S2K, DC2, EM1YO
    cool write up man!! i might give it a go when i have time
    Feb 2005
    Sid-knee
    CityRail
    Quote Originally Posted by bennjamin
    LOL @ step 3
    always lookin to make revenue huh bren
    nice write up mate
    Tom says: "Now remember kids, offsets are like women... they are best in their teens."
    Apr 2004
    EK9
    how much 12.5:1 if it were to convert to Psi?
    Quote Originally Posted by pgclee
    thats the compression ratio of an engine. This test is to judge the maximum compression in psi , to test for internal leaks etc.
    Mar 2004
    DC5S but not for long...
    few queries
    1. "turn engine over six times"... i wanan know what this means? as in rev it 6 times?
    2. also another thing...where and how much does it costs to get a compression testing tool?
    3. does low compression indicate a dying headgasket
    Quote Originally Posted by **Ghost**
    I think he means to try to start the engine 6 times per cylinder.
    few queries
    1. "6 times" means , you will hear the engine "crank" 6 times. Its an obvious noise/situation. This is to judge the maximum compression of each cylinder.
    2.The tool is about $40-60. You will hardly use it so i suggest to borrow a mechanics ( like i did) or get them to do it for you. Cost = $20 or $30 i guess . It takes only 15 minutes or so.
    3.Low compression could indicate a dying headgasket , or bent valves , or worn / leaking piston rings amoungst other things. The most important thing as said before - is that the compression between cylinders does not vary more than +/- 5%.
