Page 1 of 4 1234 LastLast
Results 1 to 12 of 37
Thread: catch can help
    Nov 2004
    Sydney
    Integra Type R
    catch can help
    hey guys, i bought a catch can recently. And im wondering how to install it. Usually it runs in line with the piping that comes out of the throttle body, (pcv i think) any heres my problem, my catch can only has one place to connect a pipe. it has a vent on top if that makes any difference. Anyway, i was wondering if there was any other way to install these things?
    Green block gangster Array
    May 2004
    twin GX160's
    its best to rout the things back to the intake.
    post up a pic of your can
    Above is a dodgy DIY method i made awhile back.
    An oil catch can is supposed to be run inbetween your PCV piping, and inlet manifold. Simply acts as a filter of excess oil vapour in the intake charge. Make sure it is sealed and free of vaccuum leaks !
    Nov 2004
    Sydney
    Integra Type R
    i was talking to a mechanic mate, he told me to connect the one pipe to the motor side and plug the hole on the intake manifold. Ill post up a pic of the catch can tomorro u guys all know what im trying to explain, pretty hard to explain without pics.
    Quote Originally Posted by BiGANG
    AFAIK the PCV system to suck/displace air from the inlet pipe, thru to the cam cover , and then circulates oil vapour from inside the engine thru to the PCV and then again into the inlet manifold. It is a vacumm run system - and needs to be unblocked. Even that little / cut in the pipe that runs off the inlet ( the pipe that connects to the inlet piping) is very inportant.
    What is your mechanic on about ?
    Nov 2004
    Sydney
    Integra Type R
    i still havent hooked it up yet. too much confusion i think. i took a pic of my can today, just have to upload it and post it up. youll c it soon. thanks benjamin for the input btw
    Dec 2004
    Sydney
    '99 Integra Type R.
    Basically, you got the wrong Catch can. They come in 2 types Vented or Sealed.
    You don't want a Vented one, as some of the others have mentioned. This is becaused your dealing with Metered air.
    This might Help:-
    http://www.c-speedracing.com/howto/c...n/catchcan.php
    Good Luck.
  8. #8
    Quote Originally Posted by OZ#227
    This might Help:-
    Good Luck.
    Good point - our hondas need the air back in for the MAP sensor ( correct me if wrong) etc to read the vacuum properly... you really do need a sealed 2 entry (in and out) can catch to be of any use both technicalyl and legally here in OZ.
    BTW , my setup shown above , catches quite abit of oil in the every day-to -day driving. Heated driving would ofcourse displace more oil vapour aimed at the inlet manifold so this is a good investment for a car that tracks
  9. #9
    Nov 2004
    Sydney
    Integra Type R
    yeh i got the vented one. heres a pic i took of it. would the vented one make any differnce to the workings of the engine. For example make it idle rough or make any other differnce? Why is it illegal?
  10. #10
    Mmm....its illegal as air vapour that contains oil etc will be vented via that vent ontop.
    And that is an illegal emission ( dont ask me on technical terms...)
    Get a catch can like the one i showed above ( and hooked up the way i showed above) , or just none at all.
  11. #11
    Nov 2004
    Sydney
    Integra Type R
    after all this, i just modded the can i had. tapped another hole on the other side and put another nipple on. the capped the top with a rubber boot i found in the garage (for now) it worked but the top of it looks shite so i have to do something about it.
    and just out of curiosity i did some experimenting on my car, and i capped the intake side and the idle was alrite. as soon as it was unplugged though it revved up pretty quick. So im guessing the pcv system wouldnt be metered in terms of the running of the car and a/f etc. Ill do some reading to try to see if my theory is right or not..
  12. #12
    Jan 2005
    Melbourne (North)
    Jazz 03Vti
    Exclamation
    if i m not wrong someone was selling these oil catchers few days back in OZHonda Traders section.
    http://www.ozhonda.com/forum/showthread.php?t=19848
